before and after...finaly!
#22
RE: before and after...finaly!
Your car looks good man. Your going to like the rack, I put one in my car. It should steer pretty easy especially with the skinnys up front. Did you get a quick ratio? The only hard part is parking in cramped areas. What kind of gears do you have in that thing to get it to 11.2's with a 306? Is it a high compression motor?
#25
thanks for the comp. No i did not get the quick ratio but i think it will still be ok. yeah its a high compression motor. I also will be changing motors next month so i might be selling this.
#26
50mikey, the k was alot eaiser then i thought it was going to be. No problems with it. I would do it if i were you it opens up the bay so much more and makes working from uner the car eaiser.
88stang.... get your self a good set of heads (i dont know what you have) and i would talk to dean or dave (i forgot) at inotvations cam shafts and you might be able to do the same.
