Adjustable Fuel Regulator
Just installed an adjustable fuel pressure regulator. Didn't necessarily need it but it will be handy for future mods... anyways, i have a 65mm throttle body, gt40 p&p heads, full length headers, comp cam with 270/276 duration and .512 lift. Question is what would be a good fuel pressure to run. Before it had about 25 idling and would go to about thirty when you reved it up, but i set it to forty and it jumps to about 48 to 50. Just wondering if anyone had any idea where it will help me the most. I haven't tried to raise it higher than that so i don't really know how it will act. Figured i would try to get some advice before i cranked her up any more cuz i don't know if it will even help. Thanks for the input.
RE: Adjustable Fuel Regulator
Adjust the FP to 39-40 psi with the vacuum line disconnected. Sounds like it's going to 48-50 because you didn't disconnect the vacuum line. Under zero vacuum you should see 39-40 psi which is fine for your setup. This should keep A/F closer to stoich (14.7:1 air fuel ratio) and return your fuel mileage closer to stock as long as you're not always in WOT.
Alright... I appreciate it... I left the vacuum line disconnected... I tried it out and couldn't tell much of a difference after installed, but like i said, it will be an extra amount of comfort when the planned charger goes on.
ORIGINAL: kev2369
When it is disconnected, plug the hose with a golf tee or equivalent so you don't have a vacuum leak while the car is running.
mrappe
09-26-2015 10:16 AM
