Heads Heads Heads...
RE: Heads Heads Heads...
ORIGINAL: 86 5.0L
not true on a stock 5.0
ORIGINAL: mrbigshot
350 at the crank. about 275 give or take at the wheels. its a good value for the money if you want to stay fuel injection. if you went carbed a 650carb, weiand stealth intake, stock 5.0 shortblock and cam, afr 165's, good headers, and 1.7 rockers made 400hp
NOTE: Kits were dyno-tested on a 306 cubic inch engine with 9.5:1 compression, a 70mm throttle body, 24lb injectors, 190 lph fuel pump, mass air, and 10° base timing.
ORIGINAL: tinman
With aftermarket what is NOT easy is figuring out what you can really use.
I did some looking a few months ago and came up with 50+ differant heads for 5.0's ......
There are probably more.....
The aftermarket SBF head thing started about '67-'68 with the Gurney-Westlake' heads and has gone on from there......
Man, your right about figuring out what you can use....with all the word of mouth advertising on here Trick Flow, Edelbrock and AFR shouldnt even have to spend money on advertising anymore
