Pushrod length?????
Pushrod length?????
I am almost finshed putting together my 5.0 engine for my 82 Mustang GT. I am using a stock block that was rebuilt and bored .030 over. I have installed "World Products" Windsor cast iron heads with 2.02" intake valves and 1.6" exhaust valves, I have crane 1.6 ratio roller rockers. Can I use the stock pushrods or do I have to use the pushrod length checker to get the size pushrods I need or will the pushrods from Ford Racing Products that are made for 302 blocks with 351 windsor heads that measure 6.905" work? The heads I have used have 1/2" headbolt holes which is common for the 351 Windsor, I have gotton special bolts to mount the heads to the block.
If I have to use the pushrod length checker what is the easiest way to use this and get an accurate length calculation.
Any advice will be greatly appreciated, Thanks, J.C.
junior04
09-28-2015 10:53 AM
Daddys Girls GTs
09-14-2015 08:46 PM
