ct emissions
ct emissions
Just got my emissions done and I friggin failed. My co was .06 above the .32 which is ct limit. I got a 302 e303 cam windsor heads edelbrock 4 barrel carb and performer intake, flowmaster3 chambers. I was told to change my plugs and get a new filter. what should I look at. this was done at 1996 rpm's. will adjusting the float on the carb work?
RE: ct emissions
what is your ignition timing set at, retard your timing that should help with the sniffer portion of the test.
douse eddlebrock even make a smog legal carb??? as i know it only holley makes replacment carbs for 5.0s
so im geusing all the parts have a carb number and the only problem was the "sniffer" portion of the test.
plugs, retard timing...pray.
mrappe
09-26-2015 10:16 AM
jpplaw
08-22-2015 09:29 PM
