TPS Adjustment?
RE: TPS Adjustment?
The throttle body blade is closing however appears to be hitting the walls of the throttle body to soon. I have cleaned the throttle body but its still the same. It is closing though. Could the throttle blade be damaged?
RE: TPS Adjustment?
Joel5.0-
I am not sure what you would learn from that. Can you explain?
The only other thing I can think of is a bad ground or Vref.
I am not sure how you would check these though.
jason
jason
RE: TPS Adjustment?
I dont understand your question. I cleaned out the throttle body in case there was some debree blocking the throttle blade from closing all the way creating higher tps voltage. I will more than likely be ordering a new throttle body or borrowing a friends to test if mine is bad.
