What's next?
What's next?
Beyond heads or cam, what is the next thing you'd do with my set up.
I have a Vortech SC TRim, 30 lb. inj. MSD 6AL iginition, BBK 1 5/8 inch headers, MSD Blaster Coil, Full 3 " mandrel exhaust with Borla exhaust. 355 gears, 73 MM C&L MAF, Pro Products 70 MM Tb, Fluidyne aluminum radiator, BBK pulleys, TF Street upper/lower, 160 thermostat, Mass Air conversion, wires, plugs, blah, balh, balh.
RE: What's next?
SUSPENSION!!! www.maximummotorsports.com
What good is it to go fast if the car will not turn or stop?
RE: What's next?
can't really tell with out knowing boost..but you need to change that stat and also go to atleast a 80mm maf..also some nice low ohm resist wires and a tweecer or pms..and yes suppension mods out the ***
RE: What's next?
I should have mentioned I have Kenny Brown welded in subframe connectors, BBK castor/cambor plates, KYB shocks/struts, a Ford racing strut tower brace, and bradn new rubber.
Still think suspension is the way to go?
RE: What's next?
yup. get a nice set of upper/lower control arms.
and if you have the money and want the work you can go with a tubular k member, tubular a arms and a coil over setup up front. That will drop tons of weight too.
You can also get a 8' crank pulley, up the injectors and pull more boost
RE: What's next?
move battery to trunk
upgrade to 10psi pulley and install http://snowperformance.net water/meth
injection and run aggressive timing.
electric fan
3-Link rearend from MM
K-member and K-member brace from MM
Coil over conversion from MM
31spline axles and differential
T-56 6 speed trans.
Aluminum driveshaft and flywheel
Stage 2 clutch
electric water pump
3G 130amp alternator
electric fan
T-56 6 speed trans.
Stage 2 clutch
electric water pump
RE: What's next?
Good recommendations and this should take me a while to get completed :-)
May be I'll start with the electric fan/ alternator and kind of ease into the rest. I'll do the battery relocation too. r.barn, you certainly love MM. I understand why.
MM makes tubular a arms too, right?
