HCI teardown
RE: HCI teardown
You might be able to hear the intake a little more, but not much, if any. Your throttle response should be a little better and you'll probably notice a little SOTP gain. As for the upper: 1 of the holes on the firewall side runs to the PCV valve, your vacuum tree goes in the other. On the radiator side, 1 goes to your purge soleniod (by the charcoal canister) and I believe I plugged the other. I actually just got rid of the charcoal canister b/c the "T" on top of the purge solenoid broke...I routed the hard plastic tube into the fenderwell by my filter. So both tubes on the radiator side of my intake are plugged, as well as the one on the back of the intake (facing the driver's side fender). I'll get you pics tomorrow if you still need them. Good luck!!
RE: HCI teardown
alright i got pics loading into photobucket now! woohoo BUT i have a few questions to go with em
WOOHO ****s here![IMG][/IMG]
[IMG][/IMG]
made a mess FAST!
[IMG][/IMG]
it feels naked!
[IMG][/IMG]
pistons
[IMG][/IMG]
[IMG][/IMG]
mores pics loading up
[IMG][/IMG]
made a mess FAST!
[IMG][/IMG]
it feels naked!
[IMG][/IMG]
pistons
[IMG][/IMG]
[IMG][/IMG]
RE: HCI teardown
more
new duds
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
now for the question. as you may know the stock upper manifold had 2 lines running into it....this one has 4 holes in it. [IMG][/IMG]
i can block the two other ones that are there but the big one on the left here i am not sure what to do with
[IMG][/IMG]
new duds
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
RE: HCI teardown
also WHAT THE HELL do i do to fill the oil in this thing now??? before the oil fill was on the valve cover..there are no holes in this valve cover. BUT they did give me a new fill cylinder??? do i have to drill a hole for it?
