Went To The Track Last Nite!
RE: Went To The Track Last Nite!
put some 4 cylinder springs under the front, the ride height wont change with the lowering springs under the rear, i have this set up. works great.
nice times and nice ride man!
If you now do some chassis work you could be running in the 13's big time and probably over 100.
I think the lowering springs are hurting you more than helping you.
Get some 4 cyl or Moroso springs and some struts on the front that are 90/10 and some rear 50/50's with some real tires and see what happens.........
look into getting a shift kit and torque converter for the car and you will be a lot happier. You did real good job for being your second time to the track. Get those 60' times down and you will be seeing better numbers
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
