Bout To Give Up
Old 08-19-2006, 05:46 PM
16FoxBody
16FoxBody's Avatar
Default Bout To Give Up
Well both heads are off, cam gears are off, and the motor still freaking hits or stops. I seriously dont know what to do anymore. I know theres nothing in my crankshaft but im gonna drop the pan later anyway. Even when the cam gear is on and the TC, i have the timing marks lined up (i think) it still hits, and even with everything off it still stops. WHAT ELSE COULD POSSIBLY CAUSE THIS TO HAPPEN?!?!!?
16FoxBody is offline
Old 08-19-2006, 05:53 PM
86 5.0L
86 5.0L's Avatar
Default RE: Bout To Give Up
EDIT: D'oh!
86 5.0L is offline
Old 08-19-2006, 06:48 PM
ooticamitica
ooticamitica's Avatar
take it to a professional and see what they say. You dont have to do everything yourself :-D rather safe than sorry!
ooticamitica is offline
Old 08-19-2006, 07:20 PM
kilobyte
kilobyte's Avatar
i agree with ooticamitica on this one
kilobyte is offline
Old 08-19-2006, 07:55 PM
stocksuspension
stocksuspension's Avatar
what do u mean it stops??? does it lock up????? could be misplaced main caps
stocksuspension is offline
Old 08-21-2006, 12:04 PM
16FoxBody
16FoxBody's Avatar
yea it stops, like it hits something, evreything is off. some1 once said something about the exhaust stroke and the intake stroke....whats that about?
Old 08-21-2006, 12:10 PM
88stangaruu
88stangaruu's Avatar
if its stopping, something bad is happening.
We really need some more info. Is the motor in the car?
What kinda motor is it? 302? 306? 331? 347?
Tell us how complete the motor is? Like how much have you gotten taken apart? What heads you running?
Are you turning it over by hand very gently?
88stangaruu is offline
Old 08-21-2006, 12:14 PM
r.barn
r.barn's Avatar
you do have the trans in nuetral right?
r.barn is offline
Old 08-21-2006, 01:17 PM
16FoxBody
16FoxBody's Avatar
its a 302, in the car, and as stated above its basically a block at this point. stock heads but thats irrelevant. the trans is in the neutral
Old 08-21-2006, 01:59 PM
88stangaruu
Alright, well it could be the rings catching the sides of the bores, the thrust bearing could have worn and the crank could be sliding back and fourth. Try pulling or pushing on the crank pully and see if the crank will move forwards and backwards, that could un-bind the crank if that was the problem. And you can take the oil filter out and cut it open and see if there is any bearing material in it. THat would be copperish/bluish metal in the filter. Or the flywheel could be locked up on something, there are lots of possibilties. Dont try to just force it to turn, thats almost a gaurantee'd way to mess something up even more.
Why did you tear the engine down in the first place? Just curious.
Quick Reply: Bout To Give Up
