what the f*ck
what the f*ck
ok i just replaced my alternator,my starter,and my battery and my stang will start up the first time u try but when u shut it off and try 2 start it again then it wont start it has a weak crank and wont turn over i got all this **** rechecked and its all good what the hell is goin on
RE: what the f*ck
well, you have to make sure your alternator is charging, put a voltmeter between the battery terminals while the car is running and you should see at least 13.5-13.8 volts,
anything less and its probably not charging, check for blown fuses or wiring problems, also, make sure your battery cables are in good shape, if the terminals are loose or very corroded it can cause this problem, but go over the battery cables and the cable that goes to the starter and make sure they look good, lastly, make sure the ground is nice and clean
