timing help
RE: timing help
Man that sucks.......I bet if you sleep on it you figure it out....
I always come up with something the next day after dreaming about it.......You may need yours for work so I know that doesn't help.
If you are tired and agrevated, like I get when I work on the hooptey, i want to smash crap in the wall....
RE: timing help
Alright....then I agree with pro 50.........one tooth and you are off enough to make it run like crap....Its sounds easy to fix but I have only advanced mine and never pulled the shaft out but it sounds like you are on track with your thinking.....
Lets see what 50 says.....
RE: timing help
it's easier with two people. But put a pencil, or something long and skinny (no no no don't put THAT in there jk), and have it rest on the top of the piston. Turn the crank with a ratchet and socket until you feel the piston reach TDC. I dunno if I explained that too well, I have a hard time putting my actions into words.
RE: timing help
or i supose i can tkae my valve cover off, put it in neutral, and crank the crankshaft by hand till the number one pisting intkae valve goes down correct?
but thats a ton of worke for me right now not to mention it would break my gasket soo ide RATHER NOT have ot do that
