Dyno #'s
RE: Dyno #'s
ORIGINAL: tuff5liter
now the only problem i am having is with the alternator is doesnt charge for crap....ive heard of alternators not working once you get higher in hp and have alot of electronics....as for electronics i have a black magic fan, digital gauges, msd, added on...i didnt think this was enough electronics but maybe now that i am making hgher hp numbers....what do you think?
You just need a 3G alternator. I have the 2G and i cant even drive at night because my headlights are to dim[&:] So just upgrade to a 3G
RE: Dyno #'s
ORIGINAL: 88stangaruu
RE: Dyno #'s
for sure, the electric fan is over taxing your alternator
go down to local alternator rebuild shop ......... you want a 3G 130amp alt.
will have to grind moutning bracket a little and make some real minor
wiring changes.
when you get close send me a PM and i'll walk you thru it
wiring changes.
RE: Dyno #'s
the factory alt. isnt worth the metal its made of. get a 3g alt. preferebly around 150amp. no more chargering issues again. lots of threads on the forum how to do it too so it will be easy
RE: Dyno #'s
Got to dyno my car this weekend at Texas Hot Rods. the numbers are 346 hp and 353 ft pounds of torque. I am happy with the numbers. [sm=smiley20.gif]
You're making that with the mods in your signature? That's not rwhp though is it?
RE: Dyno #'s
ORIGINAL: BlackLX
he left it a little rich so whenever i move to dallas i will be dropping down 4000 feet...so everything should work out nicely.
RE: Dyno #'s
no dyno is in perfect working order we used the ROL head gaskets to raise the compression but wasnt expecting that much....ill scan the dyno sheets as soon as i can but i only have access to a computer while at school, and there is no scanner available, so itll have to wait til i can get to my dads to scan it....but i will as soon as i get there in september.
ORIGINAL: luckythirteen13
either the dyno is no calibrated right or your running a bunch of compression and not telling us. or possibly, but highly unlikely, your spinning that motor to about 8 grand
RE: Dyno #'s
ORIGINAL: r.barn
wiring changes.
wiring changes.
