Need sugestions for future mods....
Ok so once i get my car running correctly (which will hopefully be soon) i want to know which way i can go with my mods. My mods right now are ported stock heads,f-303 cam,equal length headers,2 1/2 flowmaster exhaust,upper and lower typhoon intake manifold,MSD blaster coil,8mm motorsport plug wires,acccufab fuel pressure regulator, rebuilt worldclass t-5 tranny w/ pro 5.0 shifter,eibach drag springs,weld in frame connectors, 5 lug w/ 4 wheel disc brakes,3.55 POSI rearend. So i know a new MAF would help alot, i'm also thinking an e-cam but what other basic mods could i do to get some extra performance?
RE: Need sugestions for future mods....
cold air intake, 65mm throttle body, egr, upgrade maf, downgrade cam to ftw stage 1, underdrive pulleys, upgrade gears if you want, etc.
also, suspension mods, subframe connectors, etc.
ORIGINAL: 88BlueGT
suspension mods are endless. Don't forget about torque box reinforcements
upper control arms
lower control arms
tubular k member
tubular a arms
struts
shocks
springs
coil over setup's
sway bars
bump steer kits
etc etc etc
I could easily spend 3 grand on suspension parts lol
upper control arms
lower control arms
tubular k member
tubular a arms
struts
shocks
springs
coil over setup's
sway bars
bump steer kits
etc etc etc
ORIGINAL: 88BlueGT
upper control arms
lower control arms
tubular k member
tubular a arms
struts
shocks
springs
coil over setup's
sway bars
bump steer kits
etc etc etc
upper control arms
lower control arms
tubular k member
tubular a arms
struts
shocks
springs
coil over setup's
sway bars
bump steer kits
etc etc etc
Any guess's what my car would run in the 1/4 with my current setup? I live on an island so before everyone starts sayin go to the track and find out its not that easy!!
My next mod would be to move off of the island.
Why you wanting to go from an F cam to an E cam? Thats kinda going to wrong direction isnt it? I know the F cam is kinda loud, but its not that bad....
