92 5.0 cuts out when you gas it
I have a 1992 5.0 with a five speed. It is cutting out when you gas it. I have changed the fuel pump (bbk 1900), new fuel filter, new plugs and wires. Dont know what else to do. Any suggestions?
RE: 92 5.0 cuts out when you gas it
you can get a fuel pressure gauge that fits right in your fuel rail. I'd bet its your fuel pressure. They only cost about 50 bucks or so. Easy way to check that your getting enough fuel.
I had finally got it running after replacing the TPS, Map Sensor, Distr., Plugs, Wires, Cap and rotor, and EGR. Turned out to be the Mass air flow sensor the whole time. Oh yeah i also ran a fuel press. check it was all good. And compression. Thanks for the help- - - - - I guess its just trial and error with these things.
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
