Tranny Problem
Tranny Problem
ok i went to a transmission shop near me to try to figure out whats wrong with my tranny... cus after about 30 min of driving, it gets hard to shift and they said it was the clutch, but i cant see it being the clutch since it was new last year and it still grabs good and right away and it only happens after i drive a while... so now im even more confused cus i dont wanna buy a new clutch and taht not be the problem. he looked at my car for about 5 min and just felt the clutch and where it grabbed and he said it shouldnt be that hard to push down or grab that soon... i told him it was a performance clutch and its a cable so its gonna be hard and its just as hard as the stock one i had on there... so i dont know how well he knows what he's talking about.
Any help greatly appreciated
RE: Tranny Problem
You might want to check the clutch cable, sometimes the plastic fitting on the end of the shrouding can pull out exposing the metal wires (this is on the transmission side). If this happens it will cause the clutch to disengage closer to the firewall. It usually keeps getting worse and not better, but it may be something to look into.
RE: Tranny Problem
its just hard to get into gear, but its not grinding... and the clutch isnt any harder to push down than before. when i took it to the shop today, the guy adjusted the plastic piece a couple notches and thats when he said it was the clutch... is that the plasitc piece you're talking about?
RE: Tranny Problem
ORIGINAL: sasieg
RE: Tranny Problem
ORIGINAL: 5Liter Import Eater
RE: Tranny Problem
No its where the shroud meets the transmission. The picture attached is what i saw when it happened to me, those metal wires arent supposed to be sticking out.
[IMG]local://upfiles/46736/DD06102715424BF58C003F45FEC1066D.jpg[/IMG]
RE: Tranny Problem
