any pointers on h/c/i swap
Ok i just started my h/c/i swap. i got the trick flow track heat kit! I have donw this before on a few other cars, but never a mustang. I know from experience to label all the connections, and save all the bolts, but is there anything i need to watch out for, or any pointers you guys that have done this before have for me? any help is appreciated, and ill have pics up when it is all done
RE: any pointers on h/c/i swap
go ahead and replace all the sensors too.
water temp sensor
water temp sender
air charge temp sensor
IAC valve
be patient with tune in, known to have some quirks that will
need to be ironed out after install.
water temp sensor
water temp sender
IAC valve
Here is a tech article on allfordmustang.com on doing a h/c/i swap on a 5.0. It should help alot. GOOD LUCK!!!
http://www.allfordmustangs.com/techa...intakeswap.pdf
Matt's 95 Stang
10-05-2015 07:16 AM
