removin front bumper....
Old 08-22-2006, 03:26 AM
91lxstang
91lxstang's Avatar
Default removin front bumper....
whats all involved in takin off the front bumper cover on a 91 lx??? i bought a new bumper cover for the front and a new right fender..... i see that the old bumper is mounted with like round plastics pins or sumthin.... so how would i mount the new one?? would i reuse the old mounthing hardware from the old bumper cover??
91lxstang is offline
Old 08-22-2006, 03:31 AM
86 5.0L
86 5.0L's Avatar
Default RE: removin front bumper....
those round plastic pins would be the rivets and I too was wonder how to do it....
86 5.0L is offline
Old 08-22-2006, 03:45 AM
grabbem88
grabbem88's Avatar
you'll need a drill to drill out the rivits.....there is two support brackets either side of bumper also...headlight,and such...
grabbem88 is offline
Old 08-22-2006, 10:28 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Remove all the headlights, drill out rivits, remove 2 bolts on top (you might hnot have to see if they are attached to the bumper or the header panel, I cant remember), remove the 4 bolts on the bottom, and remove the two screws on the top over by the fenders. Then remove a pile of bolts connecting the fenders to the bumper. After that It should come out. Thats for an LX bumper a GT might have a few more around the fogs.
Boss_Hotrod is offline
Old 08-22-2006, 12:37 PM
91lxstang
91lxstang's Avatar
ok thanks.... so when i drill the old rivets out do i replace them with bolts??
Old 08-22-2006, 01:15 PM
88BlueGT
88BlueGT's Avatar
Im guessing you could or you could just re rivet it back on. I would tell you exactally how the front bumper comes off but I was a little tanked when I did mine so I dont remember..... all I know is that it was off the next morning
88BlueGT is offline
Old 08-22-2006, 01:25 PM
92hatchLX
92hatchLX's Avatar
After I got into a fender bender with the vert, the sawzall worked really well for removing it.
92hatchLX is offline
Old 08-22-2006, 01:42 PM
88BlueGT
88BlueGT's Avatar
LoL Yea the sawzall is a great tool... not sure about for cars though. Last time I used one on my car I ended up needing a new fan, fan schroud and radiator [&:]
88BlueGT is offline
Old 08-22-2006, 04:13 PM
whiteout 5.0
whiteout 5.0's Avatar
just be sure your fenders are for your car. I forget what year it was but they made the wheel wells bigger and the fender molding ahead of the front wheels wont line up with the bumper cover molding. I had to sawzall fit my molding panels to the front so it would line up. Then again, i have a 1988 fender, 1993 lx fender, an lx 92 front bumper cover all on an 87 gt. Actually it lines up perfect im pretty good with a sawzall. ***Its ALWAYS easier to remove the bumper and fenders as a unit the same goes for installing. The fit will be better and you'll have a much easier time with the bolts. Get a couple buddies to support the fenders while you carry the bumper.
whiteout 5.0 is offline
Old 08-22-2006, 04:42 PM
88BlueGT
88BlueGT's Avatar
The fenders opening is wider in 90 or 91 to compensate for the pony wheel.
88BlueGT is offline
Quick Reply: removin front bumper....
