What A/C and Smog pump deletes should I go with?
Old 08-22-2006, 07:14 PM
OJMiles
OJMiles's Avatar
Default What A/C and Smog pump deletes should I go with?
I just decided that I want to go ahead and take off my A/C equipment and the smog stuff is already disconnected, its just spinning the pump for no reason. I do want to keep my power steering though, so what A/C delete and Smog pump delete should I go with? Am I going to have to buy a new belt or does it come with one.
And my reasoning for deleting the A/C is because I already have another daily vehicle and the condensor is trash as it is, and the system doesnt work anyway, so I dont know if anything else needs replaced too, so I'd just rather trash it. Thanks.
OJMiles is offline
Old 08-22-2006, 09:38 PM
OJMiles
OJMiles's Avatar
Default RE: What A/C and Smog pump deletes should I go with?
Im thinking i should just take the smog pump off and get a shorter belt, what would the right belt be for this application? (A/C delete using kit, and bypassing the smog pump...) I know plenty of you here are doing the exact same thing!
OJMiles is offline
Old 08-22-2006, 09:46 PM
nitrous_bob
nitrous_bob's Avatar
just dump the smog, and use the motorsport ac delete kit.
it will make it like a factory ac delete car, and no idler pullies.
nitrous_bob is offline
Old 08-22-2006, 10:38 PM
REDS 5.0
REDS 5.0's Avatar
I just removed all the smog crapola(looks alot cleaner as well) and used a 84 1/2" belt.
REDS 5.0 is offline
Old 08-22-2006, 10:55 PM
OJMiles
OJMiles's Avatar
Did you use the a/c elim bracket and just take off the smog pump or did you use a idle pulley for the smog pump?
OJMiles is offline
Old 08-22-2006, 11:02 PM
REDS 5.0
REDS 5.0's Avatar
I did not delete my A/C and I just removed all the smog stuff. The A/C delete you speak of will place your pulley in the same location as the A/C pulley is now. I did not use a smog delete idler....waste of $$$.
REDS 5.0 is offline
Old 08-22-2006, 11:32 PM
isthatfuny
isthatfuny's Avatar
ok well i have the a/c delete..not sure what brand but the car came this way...the a/c unit is gone and the powersteering pump is now on top where the a/c used to be , but i wanna bypass the smog so anyone know the length of the belt if u remove the a/c and smog??????
isthatfuny is offline
Old 08-23-2006, 02:35 AM
isthatfuny
isthatfuny's Avatar
Bokeo
10-10-2015 08:28 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Teddi
09-29-2015 12:24 PM
Quick Reply: What A/C and Smog pump deletes should I go with?
