Injector issues. Leak? costin me $$
Was taking a peak at a couple of my injectors and they appear to be leaking. One for sure is pretty wet around the base and another is leaking somewheres closer to the top. and the others i didnt get close enough.
Im getting RIDICULOUS mileage, like 20 bux, is like 75 km's. I ordered a new O2 sensor.
I get outta my car and i smell like exhaust/gas. in a drivethrough i can smell gas.
i checked all other areas and im not leaking it, such as lines or tank or filter etc.
its drivin me nuts.
any takers
RE: Injector issues. Leak? costin me $$
Usually injectors wont leak around the bottom, they usually leak up where it seals to the rail. Try replacing all the o-rings on them. Theyre cheap and easy to replace.
As for the mileage. I doubt your leaking that much gas and its not pooling someplace. THats a couple of gallons going missing.
Make sure that injector isnt stuck open, if that happens, you will be leaking some serious gas, but into your engine and out the tailpipe
ORIGINAL: 86 5.0L
20 US bucks on 75 km? or pesos or canadian money? I hate 2 number mesurement systems......
and yes im on the hunt for the complete rebuild kit for the injectors
im losin serious fuel and if its goin out the pipes that would make sense cause of the smell.
Also, when re-installing your injectors make sure you lube the new o-rings. I usually use pentrating fluid, if you dont, youll tear the new o-rings and all of your work will be for naught.
-P.
-P.
lincolnshibuya
12-08-2015 04:37 PM
