Still Unclear
RE: Still Unclear
ORIGINAL: bouchermb
I also know about the block not being around for the long haul and a friend of mine that's a mechanic is pricing out a 331 stroker for me.
The pushrod length is determined by how radical or mild a cam you go with, right?
As for the pushrods, just buy them from the cam supplier, that way they match the cam, because you are right.
RE: Still Unclear
ORIGINAL: bouchermb
-P.
RE: Still Unclear
So no 1.7's and call Jay about the cam, huh? So the custom grind cam won't need different length pushrods because my cam won't be a solid one, and I'm not getting head/machine work done.
It also sounds like whoever I get to do the cam, should be the one to supply me with the pushroads as well. With the RR's, it almost sound like the 1.6RR make more sense for my street application, but now I'm confused about the 165 or 185 heads.
RE: Still Unclear
I would get the 165's for a nice street car... it will match with your manifold also.
Also, did you ever consider adding more boost? with a crank pulley, power pipe or blower pulley?
