Still Unclear
Still Unclear
I know this is a completely exhaused topic, but with so many experts on this site, I'm asking again.
I' want to do cam/heads, and soon, but want to see what type of cam, lift/duration/brand you'd recommend with my set up. Also I'm looking to do AFR competition 165 heads and wondered what type/length of hardened pushrods you'd go with. I'm also planning on the Crane 1.7, 3/8 stude mount RR's, unless that's not a good mix.
RE: Still Unclear
I have a 5 psi SC, 30 lb. inj., pulleys, 73 MM MAF, 70 MM TB, MAss Air conversion, TF STreet Intake, MSD 6 AL ignition control module, blaster coil, Fluidyne aluminum rad, 190 lph FP, BBK headers, full 3 inch exhaust, Borla mufflers.
RE: Still Unclear
Well id go with a Supercharger cam, Custom grinds can be ground for your s/c and work best with it, the 303F cam is a supercharger cam, lots and lots of top end power with it, i run it N/A and its got tons of top end on it, i like it. Probably work good with 5psi. its got .512/.512 and 226/226, so its not to radical.
RE: Still Unclear
That's the best input I've gotten so far.
I've also heard a bunch of good things about Jay at Camshaft Innovations, but looked at the build sheet and realzied I can't 1/2 of the stuff they ask on it.
RE: Still Unclear
I also know about the block not being around for the long haul and a friend of mine that's a mechanic is pricing out a 331 stroker for me.
The pushrod length is determined by how radical or mild a cam you go with, right?
RE: Still Unclear
ORIGINAL: bouchermb
As for your rockers, 1.72's will make more peak power, but the stock 1.6 ratio will make more power through the whole rpm range. Unless all youre trying to do is get more lift without the added duration. If thats the case then go with the 1.72's.
-P.
