head upgrade
head upgrade
I am looking into getting a new set of heads for my car. Right now I am running Trick Flow Twisted Wedge heads with the 1.94 valves. But, with my 347 I feel they are way to constrictive and robbing my of a lot of power. But, I am also running 11.5:1 compression with the Trick Flows, which are 60cc chambers. So, I would like to find something affordable with more flow and bigger valves and chambers. Any insight will help.
RE: head upgrade
vfast, what do you mean by reliability will be compremised. I was looking into the world products/ roush windsor sr. heads. do you know anything about them or how good they are? i want to keep my car streetable and the afr 205 is a race head so i dont know if i would go with that. plus the afr's only have 58cc chambers which would through ym compression up higher which i dont want. i need to bring it down or keep it the same.
RE: head upgrade
like someone said get your heads ported also t/w come with 2.02 intakes.a ported t/w can flow 300 + cfm on the intake and 220+ on the exaust that kind of cfm could get you in the low ten maybe even faster there is a formula for air flow for hp some where.I dont think that the heads are holding you back that much IMO.I dont take any thing away form the AFR but a ported T/W will make big HP. any way a out of the box CNC ported AFR dont flow that much better then a out the box non ported TFS T/W
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
