Squeeling noise...
Squeeling noise...
There is an irritating squeel/squeek noise that happens almost every time I take a left turn, and it's been happening for quite some time...very very annoying
It sounds like squeeky brakes, although when I make the turn I don't even use the brake
Anybody have any clue what it could be?
RE: Squeeling noise...
check the dust shields and make sure they aren't rubbing on the back side of the rotors. You'd be surprised how often those things can get bent inward and rub on the rear of the rotors causing that annoying noise. It's free to check and only takes about 10 seconds. And if that's the issue, just bend them back.
its not a wheel bearing, or dust shields... its your balljoints. Ford is notorious for having balljoints squeal when they go bad. My Cobra did it, my probe did it, my fathers f150 did it. and one of my customers with a ranger had it happen too.
ORIGINAL: AdderMk2
^^ I agree there. Id check my steering rack to and my power steering fluid, just in case
Lone_Star_Stang
04-15-2006 08:52 PM
michaeldoggrell
02-16-2006 12:57 AM
