Pros/Cons of Bumped Timing...
08-25-2006, 08:47 PM
RE: Pros/Cons of Bumped Timing...
Wow i'm at 15 degrees with 85 octane and no pinging at all. Maybe altitude has some effect on it.
08-25-2006, 09:19 PM
Yukon Cornelius
also reduces engine temps
08-25-2006, 09:22 PM
ive found that when i bumped mine to 12 it had less low end torque and hp. around 2500 it had a noticable diferance in more power
08-25-2006, 09:48 PM
So should I bump it up from 10* to 13* ??
I think I'm gonna do it with my buddy Luke who probably knows a little more than me what he's doing
08-25-2006, 09:57 PM
I had mine at 14, and it pinged w/93 in it. So I backed off to 13. I'm guessing the timing marks on the balancer aren't very accurate. Everyone seems to have different results.
08-25-2006, 10:03 PM
I have heard 3-4 hp per degree of timing............I would probably say closer to three.
Mines at 16* and I run 93 and no pinging............
08-26-2006, 01:10 AM
This *pinging*... is it noticable like will you know when it starts? Does it only do it when in gear or whenever reving period?
08-26-2006, 02:13 AM
u have to set the timing with the spout connector disconnected or else it would run badass for 3 minutes then go back to normal
Lethaldosage423
10-19-2015 12:12 AM
Dokilar
15
10-16-2015 08:13 PM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
09-30-2015 10:13 AM
mungodrums
Suspension
09-24-2015 10:12 PM
50 ,
93 ,
advance ,
advanced ,
afetr ,
bump ,
bumped ,
bumping ,
car ,
con ,
idle ,
mustang ,
pro ,
proscons ,
timing
