Running at the strip with a bad throwout bearing?
Going to the mason dixon dragway tonight...I have a bad throwout bearing...is it safe to run or should I not run until its fixed?
RE: Running at the strip with a bad throwout bearing?
I dunno if I would run it with a bad throwout bearing... Grn N Gry 5.OH has the same problem right now and he tries to avoid driving his car.
Where in MD do you live? I go to Mason Dixon to drag, too.
Yo man, a bad throw out is a rough way to run, but if you got the $$ to fix the damage it does to your clutch then, hell run 'er. But if your heading to Mason Dixson i say you should wait till sunday, its Ford day!! I'll most DEF. be there
BTW I'm just outside of Winchester VA, pretty close to Fredrick
https://mustangforums.com/m_1842428/tm.htm I know
I'm going to be replacing the clutch, pressure plate and baering next month anyhow. I can wait until then to run I suppose.
