Idle...
RE: Idle...
I mean outside air...And as for the idle bein higher in the cold i dont think it should be at 2k thats crazy. And i drive a half hour to work and it would be warm by then but it still does it at 2k. How would i check the idle bypass soleniod?
ORIGINAL: bakedog
by hot or warm to you mean temp outside or the engine warming up. bc it is supposed to idle higher when the engine is cold.
RE: Idle...
You can either check it by putting a meter on it, rev the engine up and down and see if theres a change in voltage (that will tell you if it's getting the volts to move it) or more likely pull it apart check it for sticking and/or if the diaphram is torn...
