help
Old 08-27-2006, 01:10 AM
wh18skal
I ♥ Acer
wh18skal's Avatar
Default RE: help
there is no fuses under my hood and i checked the one's under the dash and there isnt one for the fuel pump.
and the wires for the fuel pump r the same that was in there but i think i will try and check them b/c that is the only thing left i can think of
wh18skal is offline
Old 08-27-2006, 01:13 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: help
Have you checked for power to the relay and the pump?
PRO50SC is offline
Old 08-27-2006, 01:15 AM
wh18skal
I ♥ Acer
wh18skal's Avatar
Default RE: help
i have a volt meter but i dont know what wires to test
wh18skal is offline
Old 08-27-2006, 01:23 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: help
You will need to get a wiring diagram.
PRO50SC is offline
Old 08-27-2006, 01:24 AM
wh18skal
I ♥ Acer
wh18skal's Avatar
Default RE: help
do you know of a website where i can get one?
wh18skal is offline
Old 08-27-2006, 01:29 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: help
ORIGINAL: wh18skal
I thought aI had one book marked but I can't find it. maybe someone else will chime in.
PRO50SC is offline
Old 08-27-2006, 01:35 AM
wh18skal
I ♥ Acer
wh18skal's Avatar
Default RE: help
i found 1 but thxs a lot for your help
wh18skal is offline
Old 08-27-2006, 01:37 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: help
ORIGINAL: wh18skal
NP, good luck!
PRO50SC is offline
