HELP! SPRINGS
HELP! SPRINGS
I was going to do my springs today I bought BBK lowering springs front and back, they drop the car 1-1/2, i was wondering is there anyway that i can remove the front shocks without a spring compressor? and are spring compressors vehicle specific? [:@]
Thanks guys
Thanks guys
RE: HELP! SPRINGS
ORIGINAL: primetime5.0
I am lost by this^^.......... you dont need a compressor to do the front suspension
RE: HELP! SPRINGS
I have heard you need a spring compressor to get the front springs out but i dont know if you actually do, it might just make it easier. Shouldnt need one to get the new springs in though... I'm not sure how much foxes differ from my SN95.
RE: HELP! SPRINGS
ORIGINAL: OnyxCobra
+1 Just undo ur swaybar link, break the balljoint and then just push the control arm down as far as you can and rip that spring outta there.
RE: HELP! SPRINGS
Nope is not that easy... since you have the lowering springs i bet u might be able to throw it up in there. but i would use spring compressors b/c i but the oem springs back in mine and it was a bitc*.
1. i say remove the strut so u have room to work.
2.lower the lower a arm
3 if yo u can rip the spring out do it.. but those springs have a lot of tension if there the orignals so be careful
4. Put the lowering springs back in and bolt up
