which heads, intake, injectors, tb, fuel pump,
i am planningon building a 408w stroker i will buy a chp shortblock and then go from there
i am putting a 10-12 psi supercharger.
which heads?
which intake?
which injectors?
what size tb?
what fuel pump?
which heads?
which intake?
which injectors?
what size tb?
what fuel pump?
RE: which heads, intake, injectors, tb, fuel pump,
AFR 185 heads min, 205's would be better
30lbs injectors with no boost and 42-60lbs with boost
TrickFlow intake for 5.8L engine or GT-40 intake off Lightning Truck if you want to run Kennebell blower.
255 lph fuel pump
70-75mm TB
255 lph fuel pump
70-75mm TB
