Which Felpro HG to get?
FEL-9333PT-1
FEL-8548PT-2
FPP-1011-2
FPP-1011-1
& all will fit my car. I'm just not sure which is the best.
FEL-8548PT-2
FPP-1011-2
FPP-1011-1
RE: Which Felpro HG to get?
id get the last one.
the first two clearly say "OEM stock replacement Fel-Pro head gaskets are ideal for stock rebuilds for street-driven cars and trucks."
its stock, so it sux, and i doubt your rebuilding your car to be stock so neither the first two sound any good.
FPP-1011-2 is a decent one. this is the gasket that afr recommends when buying their heads so you know its good. its the one i used to have when i was n/a but when i got my sc i didnt have the fuel system to handle the power yet, when lean and blew the head gasket.
talked to afr again and they said for boosted motors FPP-1011-1 is ideal. ive been running that gasket for a while now. 461rwhp and its holding fine. i also use head studs tho which clamp the head down better then a head bolt. head studs about $80 for a set
