Fall and Winter Project for Spring Ready, Which Shall I DO!?
Ok gang , im sure to see 2006-2007 Mustangs, Maybe Camaro , vetts, and ricers running at least 300+ horses.
Im good for 500 horses, which shall I do to get at least 400 Hp, to put up some competition, im at 315 or so at the crank.
Im also getting a Forged Racing Driveshaft, Balanced, Driveshaft Safety Loop, Forged Moser Axles, Bigger Brakes and Rotors from Brembo, Lowered 1 inch rear, 1/2 inch front, with Street Springs and Custom 60/50 shocks, Roll Cage and Structual Supports for strut towers and undercarriage, SLICKS, fiberglass rear hatch, different ratio rack and pinion, offset polyurethane rack and pinion pushings, bigger sway bar and poly bushings.
RE: Fall and Winter Project for Spring Ready, Which Shall I DO!?
I say run a Novi 1000 with upgrades.... get it up to 10+psi, throw on supporting mods and be happy. Only cost about 2,5K including everything.
Stroke and balance it with forged internals.......that way your engine is already badass and you can put whatever you want on it when the time comes.
i need more votes, guys, the date is sooner now
I just got a $600 job, Honda, turbo instal and basic motor rebuild, yeah I dont charge much lol, considerin that a meen 1 week job.
hes going forged internals, etc ,then a balance.
If your thinking about a 347 you might as well buy forged internals for it anyways. Then you can decide your path from there, nitrous, turbo, s/c or heads. (And by path I mean getting the correct compression ratio etc)
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
