cars do that sometimes when they have blow by issues... run a compression test and hit up a wideband O2.... you might be too rich and your washing your cylinder walls
Sounds like a ring issue to me... When the piston rings get worn down more exhaust gets past them (blow by), and collects in the fuel. I might be wrong, but that's my vote. Injectors might indirectly cause this problem, I'd imagine that if the fuel pressure/rate is increased, that more exhaust would be available to get past the rings and into your oil. Good luck
