Comp Cams Cam Help
RE: Comp Cams Cam Help
I haven't used that cam...
But the reason it is better than the Ford letter cam is that the Comp Cam has a split lobe design. The intake and exhaust lobes are not identical.
The restriction on Windsor heads (whether stock or aftermarket) is usually the exhaust port.
A little more duration/lift on the exhaust side will help alleviate that problem, without causing drivability problems to increase dramatically.
Well, that's how I see it anyway.
jason
jason
junior04
09-28-2015 10:53 AM
