burning oil after sitting
ok, i just bought a 88 mustang gt, the guy who i bought it from told me that it has been sitting for 7 years and i got it running and it seems to be burning oil really bad. one of my buddy's told me that once i let all the old gas and everything burn out it will go away.. is that true?
RE: burning oil after sitting
waht color is the smoke and how long ha sit been sitting .If it fule injected the gas is probaly bas so I would drain it or suck it out with a siphion hose change fuel filter and fill it up with new gas and dump a bottle of lucas injector cleaner in it with a bottle of fuel drier and drive it around town til the tank empties then changer your filter agian . If you run the old fuel in ther you might damage the the fuel system
If it's blue smoke, theoretically, you may have one or more sticking piston rings--particularly if the car has been sitting a while. If this is the case (which in my experience, it never is), a few hard romps on the throttle may clear it up. Otherwise, either the piston rings are worn, or the valve seals are bad.
ORIGINAL: Derf00
valve stem seals are probably dry-rotted so that smoke may never go away (if it's bluish/black)
