ball joints
#23
RE: ball joints
TRW is a high quality ball joint and exactly what I used. If they are shot, they need to be replaced. I am not sure what was meant by damaging the top of the spindle nut unless you can't swing a hammer because you should only be making contact with the old ball joints to get them out, and the lower control arm to get the new ones in. And vibration could be a number of things, including wheel balance, which I am surprised no one mentioned. But again, if a mechanic who you trust said you need new ball joints, I would replace them. And yes, these could cause you steering issues. Good luck.
#24
RE: ball joints
ok im going to attempt this tonight i think. ill try to strap something around the spring incase it flys off. Im not going to pay $200 to have this done. i need the experience.
#26
RE: ball joints
The spring should not come out. You should never have to lower the lower control arm so far that the spring could even clear out. In terms of torque the wheels, I never put a torque wrench to the lugs. I just tighten them from experience with a breaker bar. Just never overtighten them. In terms of reinstalling the rotors. Put the rotor on the spindle and then put on the castle nut. Tighten everything down, then right before its completely tight, rock the castle nut back and forth just a few times to cinch it down and make sure everything seats correctly. Then install a new cotter pin and your good to go. You may want a string or piece of wire to help hold the caliper out of the way and to keep you from having to take off the brake hose, therefore keeping you from having to bleed the brake system. I think my total install time was about 4 hours including running back and forth to my box to grab tools.
#28
RE: ball joints
ORIGINAL: P Zero
Youre supposed to replace the whole lower control arm, not just the ball joint, thats the proper repair. You should get the ford racing ones, they have better bushings in em and have a little bit different angle to help your car corner better.
In order to replace the LCA's, youll need to remove teh spring so youll also need a spring compressor.
-P.
-P.
If you want to replace the stock control arms with a better performance part, by all means go for it and you will see a suspension improvement. But it is not necessary.
#29
RE: ball joints
ORIGINAL: LOUDexhaust
ok thanks. should i use loctite any where?
Don't take this the wrong way, I am not trying to belittle you. I am just trying to look out for one of my fellow mustang brothers and make sure he and his car last a long time.
#30
RE: ball joints
its not as daunting task as many make it seem. when i changed ball joints for the first time i bought a ball joint press, its like a giant c clamp. i did it do i could do it with the spindle still attaches to the car. $89 and all you do it use an impact to press them out.
