ball joints
#61
RE: ball joints
yes they're the right ones. the hole is just a little higher. they were $20 a piece so probably not the best. anyways, we got 1 side done. we removed the shock, wasn't in the instructions but seems to have worked well. got the second one out with a gear puller. going to finish tomorrow. btw the right rotor was pretty loose, spun very freely. maybe that could be a sorce of the vibration? thanks for your help everyone.
#66
RE: ball joints
When tierods go bad, they WILL cause a vibe. It wont shake all the time (unless theyre really bad and about to snap), itll usually shake the worst on long drawn out mild corners on the E-way, and usually not shake or shake less when going straight. Id say check your tierods.
-P.
-P.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
