help locating where this ground cable goes!!
I've just put the rebuilt motor in and i've been trying to troubleshoot why the fuel pump relay's not coming on...i'm thinking i might have a ground problem...anyways, i came across this ground cable sitting on the floor and im going crazy trying to find where it goes...
RE: help locating where this ground cable goes!!
hey will jus wanna say thanks...that was the plug that was causing all my problems.....it plugged into the harness around where the ignition coil was...one end went to battery ground and the other to chassis....guess it was the main wiring harness ground...soon as i put it up everything started working....again...thanks!!
nothing, juz did a stock rebuild....i bought the car 3 yrs ago, and its just been sitting there rotting away....now since the t-top was leaking, water soaked the carpet and rotted away the floor pans...figured i'd juz do stock rebuild now....get it up and out on the road...then in a year or two, do something crazy....
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
