Labor cost on S/C installation
RE: Labor cost on S/C installation
I helped my friend install one over the winter time. It can be done in a weekend if you have ALL the parts. You are going to need to pull the oil pan off and drill/tap a fitting for the return line. Also, I had to modify the stock radiator shroud with a dremil to get the fan to fit. Also, depending on the kit, you might need a new tensioner. I know the S-trim i installed didnt have it. Just double check your list and make sure u got all the ****. Also, do you have an upgraded fuel pump? thats gotta be wired in.
ORIGINAL: Black Snake
We charge 100 dollars an hour, if its a Votech or voretch based charger it takes us 3 hours, Procharger takes about 4, cause of the pipes and some cutting envolved
