one bent foxbody
one bent foxbody
the other day i was rotating my own tires, bc why pay someone when you can do it your self, and noticed that the rear right tire protruded out form the bumper more than the other wheel did. i took a step back and it looks like the axil is shoved to the right about an inch... i know how easy the foxes spin out and i thought maybe it had been in an accident and suffered a bent frame, however the car looks streight. i had some mustang specialists lift it up and look at it, but they could not see any frame damage at all. i spent quite a bit of time looking at the lower control arms, torque boxes and the upper control arms... and all the stuff that would bend under pressure and found no problems. wtf, i have no idea, does the car have any type of body mounts that may have gotten tweaked in a minor rear end collision??
RE: one bent foxbody
its a unibody, did you mesure the distance form the upper and lower control ams to the sides of the body, axle , etc., if the axle was moves laterlly an inch the u joints would feel that and you'd hear it, it may be a body issue, take it to a local body shop and find out where the bosy mounts are located, most likely in the trunk and floorpans, does the car track straight down the road? are the front and rear tires in line with eachother?
i thought the same thing about my car
i watched it while it was on a dyno and man that rearend looked like it was gunna fall out
got it aligned and turns out the rims were really bent giving the illusion
i really need some new rims
Grab yourself a measuring tape and park on a flat surface. Make sure all your tire pressures are equal and nothing is weighting the car down. Now start comparing points from other points. You can use factory holes, joints, etc...
If they are all fine then the rear alignment could be bad...you could be crabbin'
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
