Motor mounts...
Hi,
How hard is it to install the motor mounts? I just got them and look underneeth the car and it looks like a PITA... How long does it take, its my daily driver so the car has to be running on the weekdays. Do you think it can be done over this 3 day weekend with only simple tools that I have+plus a really good jack? I would hate to have a shop do it cause I know there gonna charge $70 an hour and they will take their time doing it. thanks |
RE: Motor mounts...
Not hard at all............about an hour....depending on how much beer you drink......
In the cases I have seen only the driver side motor mounts break. I changed mine with 4 jack stands and a jack..... 1. Grab beer and various tools........ 2. Put car on all jack stands.......open beer......... 3. Loosen driver side motor mount (the huge nut)...no disrepect to your knowledge of cars......everyone is on a different level when it comes to working on them. 4. Loosen the the two bolts that attach the mount to the block...... 5. Place a block of wood on the jack and then place under oil pan, raise motor a couple of inches to remove mount. 6. Open beer # 2. 7. Place new motor mount in location.......bolt to block 8. Lower engine and tighten big nut........ 9. Open beer #3 10. Do the same thing to the other mount........after that you should be through about 5-6 beers....and the job is done....... 11. Dont drive for awhile....... If you replace the motor mounts get Energy Motor Mounts and Trans Mount......They run like 159.00 for the set, they are worth it trust me.......replace both motor mounts and do the trans mount too..... Hope this helps......and your car is clean dude......wish my vert was so shinny......... |
RE: Motor mounts...
thanks a lot!!
RE: Motor mounts...
ORIGINAL: SSKiller Hope this helps......and your car is clean dude......wish my vert was so shinny......... |
RE: Motor mounts...
Anytime bro......
RE: Motor mounts...
thats a really good and accurate explanation, including the beer consumption!:D
RE: Motor mounts...
....valcoor what have u done to your stang??
RE: Motor mounts...
ORIGINAL: MEM 302 5.0L ....valcoor what have u done to your stang?? |
RE: Motor mounts...
Get the blower Boost is fun........
RE: Motor mounts...
ORIGINAL: 7upedition thats a really good and accurate explanation, including the beer consumption!:D |
