SWAPPED A9L FOR A9P...RUNNING RICH?
RE: SWAPPED A9L FOR A9P...RUNNING RICH?
Looking at Spark Advance per RPM
A9P
RPM_______0___1600___2250___2600___3500___5000___1 6384
Advance___18___18_____22______23____22_____26_____ _26
A9L
RPM______0___1000___1800___2150___2600___3500___50 00___16384
Advance__8____8______18.5____21.5___22.5____22____ 26______26
Peak Total is the same but the A9P has more timing lower in the RPM's
Just in case someone else thinks this is as interesting as I do...
X3Z
Advance__8____8_____18.5____21.5___22.5____22_____ 25______25
This shows how the 93 Cobra was actually a weaker tune than the A9L.
Keep in mind this is only one of many timing tables in the EEC-IV. There are compensations for ECT, ACT, even TPS and tps rate of change.
jason
A9P
A9L
X3Z
jason
By the way ANYONE can download the tweecer software - CalEdit and Calcon.
You then use CalEdit to load the Ford Factory tune files (always in .bin format)
CalEdit is where I just looked up the above info.
Tweecer software is free, its the hardware that you have to pay for.
http://www.tweecer.com/downloads.htm
jason
jason
I dont have any number with the tweecer yet either. I just runs and idles a lot smoother. for having solid motor mounts my car has minimal vibration inside at idle, when it used to be horrible.
Matt's 95 Stang
10-05-2015 07:16 AM
