difference between a regular 5.0 and a cobra 5.0??
RE: difference between a regular 5.0 and a cobra 5.0??
ORIGINAL: frankbullitt
Cobra 5.0 has different intake manifold. Im pretty sure thats the only difference engine wise.
1995 Cobra Features / Information:
High Performance Engine:
- Configuration 90/degree V-8
- Bore x Stroke 4.00 X 3.00 in.
- Displacement 5.0 L / 302 cu. In.
- Compression ratio 9.0:1
- Horsepower (SAE net) 240 hp @ 4800 RPM (under-rated for insurance reasons)
- Torque 285 lbs./ft. @ 4000 RPM
- Fuel system Sequential Electronic Fuel Injection EEC-IV
- EEC-IV Computer calibrated to Cobra
- Throttle Body Single Bore, Large Diameter- 60mm
- Camshaft Revised, Lobe Lift 0.2822 in. (Intake and Exhaust)
- Intake valves 1 per cylinder, diameter 1.84 in.
- Exhaust valves 1 per cylinder, diameter 1.54 in.
- Pulleys Modified to Slow Drive of Accessories
- Rocker Arms Ford/Crane Roller Rocker Arms 1.7:1 Ratio
- Flywheel Lightened by 2.7 lbs.
- Pistons Cast Aluminum Alloy
- Cylinder Block Cast Iron
- Cylinder Heads GT-40 Design, Cast Iron with Ford/Crane roller rocker arms and stiffer springs
- Intake Manifold High Flow Cobra intake Plenum Cast Aluminum Upper, Cast Aluminum Lower
- Exhaust Headers Tubular Stainless Steel
- Exhaust System Dual Stainless Steel
- Oil cooler
I know theres more, but the 95 cobra and 93 cobra are a bit different. If you want to go do a conversion your better going with the gt40 intake manifold and heads.
