gas
Old 09-03-2006, 02:38 AM
alec3369
alec3369's Avatar
Default gas
what gas is everyone running in their stangs? Is it safe to run 87 in a stock 5.0?
alec3369 is offline
Old 09-03-2006, 02:40 AM
FullAuto
FullAuto's Avatar
Default RE: gas
I run 91. But 87 is safe is most 5.0s.
FullAuto is offline
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: gas
93 in mine and 89 in my wifes.
PRO50SC is offline
Old 09-03-2006, 02:59 AM
MEM 302 5.0L
MEM 302 5.0L's Avatar
Default RE: gas
i run 87 in mine...mines stock .......thinking about puttin 91 in it and changing my timing...
MEM 302 5.0L is offline
Old 09-03-2006, 03:43 AM
sbx213
sbx213's Avatar
Default RE: gas
87 for now since its bone stock. I plan on using 93 after my setup.
sbx213 is offline
Old 09-03-2006, 03:46 AM
Twotone93stang
Twotone93stang's Avatar
Default RE: gas
I run 87 right now and seem to do fine. My car is basically stock. So maybe thats why it works out.
Twotone93stang is offline
Old 09-03-2006, 03:50 AM
georgiaguy246
georgiaguy246's Avatar
Default RE: gas
i've heard run 93 all the time, but if you want run 87 if its stock. but if you start to mod run 93 it would be for the best!
georgiaguy246 is offline
Old 09-03-2006, 03:59 AM
jthorn9
The Godfather
jthorn9's Avatar
Default RE: gas
I try to run 93 when it isn't too damn expensive, but if need be I'll run 87, but believe it or not, my car gets nearly 3 mpg better with 93 over 87, I nearly passed out, but when I've done several long trips in the past three weeks and when I used 87 I got around 20-21 mpg doing mostly hwy, then I put in 93 and get 24-25 mpg, it's absolutly rediculous the difference that it makes.
jthorn9 is offline
Old 09-03-2006, 04:28 AM
MustangMadness7
MustangMadness7's Avatar
Default RE: gas
I run 93. It cant hurt, and i get better mpg.
MustangMadness7 is offline
Old 09-03-2006, 04:31 AM
ridebmx4140
ridebmx4140's Avatar
Default RE: gas
93 because of timing... and its not my DD so i can afford to
ridebmx4140 is offline
Quick Reply: gas
