wiring cut, what now?
i bought a fuel injection harness out of a t-bird today, when i pulled it out of the firewall, someone prior to me had cut some wires. now i am wondering if they are needed and what they go to. only 2 wires out of the cut ones go to the cpu, the rest to the main wires. does anyone have a wiring diagram that tell me where they go? it is for my conversion project and if i dont need them i will just cut them out but if they are needed i need to go get another harness. do the t-birds and mustange have the same harness and just different cpu's? please help!!
RE: wiring cut, what now?
I'm guessing there are 6 wires cut total? I had had to cut 4 wires that went from the harness to the fuel pump relay when I removed my harness. Maybe the other 2 got cut by accident when cutting the ones that went to the fuel pump relay.
Well it sounds like your converting a 65 mustang to efi right? A speed density computer will work but your pretty limited to a stock cam or an isky cam made for speed density. If you get a chiltons manual for a 88 tbird it will have all the wiring diagrams. Later tonight I'll check what color the fuel pump relay wire colors are.
jwog666
12-27-2021 08:09 PM
