won't crank
won't crank
my mustang wont crank over. a buzzing sound is coming
from the starter area but will not crank over at all. i have
pulled the starter and had it tested that is fine,the battery
is strong"red top optima.i replaced the solenoid "fenderwell"
i also replaced the ignition module under the steering wheel
i have the battery in the trunk with a new 130 amp alternator.
should i replace the coil next ?? any ideas are welcomed
RE: won't crank
Instead of continuing to waste money throwing parts at it, correctly diagnose it or take it somewhere that can. Have you checked all the connections? Are you sure the battery is fully charged? Will it start by jumping it?
RE: won't crank
are you sure the starter is good . I have had starters that would spin but the forks wouldnt engadge or would spin out of the car but didnt have enough toruqe to spin the fly wheel
RE: won't crank
ORIGINAL: PONY GUY
RE: won't crank
yeah Ihave had problem with reman starts before on F450's ontime i got so pisse dwith 2 remans beiing junk . I bought a brand new one form the ford dealer and smashed the remans with a sledg hammer and sent the back as recived as dammaged LOL
RE: won't crank
hmm try tapping the starter with a hammer and see if it'll crank over. that's something my uncle used to do to get a bad started going. i'd say if it starts after that, then it's def the starter.
lincolnshibuya
12-08-2015 04:37 PM
09-29-2015 03:23 PM
