Brakes are horrible
Brakes are horrible
I just put new front brake pads on my car Friday because it wasnt stopping very good with the old pads, even though they werent really worn at all. They were a little glazed but still almost as thick as the new ones.
I used Wagner pads because the guy at the parts store said they were great pads to use. Theyre not the cheapest pads they had.
I didnt replace the rotors because they seem to be pretty good. Theres no grooves or waves in them.
The rear brakes were recently replaced by the previous owner.
The problem is that its hard to stop the car. When I hit the brakes hard they just lock up and the car skids. Also it smells like burning brakes when it stops hard.
It doesnt seem all that safe when that happens.
What could be the problem?
I dont want to upgrade the brakes to SN95 or Cobra just yet because I cant really afford to right now. I just want to be able to stop better with the stock set up.
RE: Brakes are horrible
ORIGINAL: PJB
ORIGINAL: 86 5.0L
well, duh, if you press hard, the wheels WILL lock, sometimes you think you're not doing it hard but you are
ORIGINAL: PJB
ORIGINAL: 86 5.0L
ORIGINAL: PJB
ORIGINAL: Twisted
How much better braking can you have than the wheels locking up? Sounds like you have traction problems.
ORIGINAL: 86 5.0L
ORIGINAL: PJB
how is the feeeling in your brake pedal ? Does it feel mushy? does it come back up after you push it down ? when your removed your capilers did you clean and re grease the caliper slides???
