You can check your bolt that adjusts your idle, could be backed out... you can take an 8mm socket and give her a little tightening if it has backed off... but i would check for vacuum leaks first... Not gonna be you ignition module more than likely... they usually wanna lay down on ya after they warm up... good luck
