Easy EGR removal
Easy EGR removal
Recently found this little $20 plug, that will bypass the EGR to EEC plug
and tells the computer that the EGR is closed, so you can remove it with no issues.
Just thought I would share
http://fordfuelinjection.com/?p=61
RE: Easy EGR removal
ORIGINAL: silver91gt
leave your egr on, I have one of those and all it did was cause it to drive like crap when driving slow.
And, when you look at the EEC program there is no reason why it wouldn't work.
I bet you have something else going on.
Do you get any diagnostic codes?
A few years ago these were available on ebay as well.
Be sure to secure it to the plug, mine fell off one day. I heard it bounce around under the car, then it was gone forever.
jason
anyone else have any experience with these ?
i have my egr off and am considering buying one of these...
also how did you guys hook up your throttle cabes to where it should be(on the egr plate)? .. just seeing what anyone else came up with
thanks
thanks
ORIGINAL: bernout
thanks
thanks
Either way you will want to plug the egr ports in the lower intake, to prevent excessive heat soak of the intake. If you don't have the egr functioning, then there is no reason to let the egr gasses heat up your intake.
I've used metal filler epoxy for this before.
jason
