thermostat ?? ??
thermostat ?? ??
i have a 1987 5.0 efi and im wanting to know if it will be ok to run my engine with out a thermostat i do not drive it in the winter so i dont need heat fast so im just wondering if it will screw anything up as far as the computer reading the temp or something like that !!! thanx for you help !!!!!!!
RE: thermostat ?? ??
ORIGINAL: 1BADASSLX
Why do you want to run without a stat?
Are you having temp issues?
jason
i'm inpatient and haven't got one yet just got my motor back and put together ready to go but i will get a stat tomorrow i thought it would help on temp as well check out pics
[IMG]local://upfiles/10499/B55AE8B5241545F2983173530E6CAF75.jpg[/IMG]
[IMG]local://upfiles/10499/1EF6EA303BC543C69AD243DF2BD92F41.jpg[/IMG]
[IMG]local://upfiles/10499/54AA11875E1042A093D775ECF44DC192.jpg[/IMG]
[IMG]local://upfiles/10499/98D45057D59D42FC86D94FE5F14E8FC7.jpg[/IMG]
[IMG]local://upfiles/10499/924E8584A5AE4CD99E5889030B0B681B.jpg[/IMG]
It looks like a fun project you have going.
Colder coolant temps are not always better. You want the coolant to be between 190-205F, depending on who you talk to this can flex a little though.
Engine temps below 180F greatly accelerate cylinder bore wear. As the temperature drops, cyl bore wear increases rapidly.
Also, an engine will make more power once the coolant temps are above 180F.
Warmer oil will thin out, decreasing losses through the oil pump.
A hot combustion chamber will help to vaporize the fuel. This leads to more complete combustion, yielding more power and economy.
Since this is a new motor, I would go with a 195F stat. If you don't have any deficiencies in the cooling system the stock stat should work very well.
If your temps start getting too high (like over 220F) then switch over to the 180F.
It would be better to upgrade cooling system parts instead however.
Keep in mind that the temp of the coolant is of primary importance. The rating of the stat is secondary.
If the temps in your part of the country are 100F or higher, then using a 160F stat may be the only way you can keep the coolant temps close to 200F.
Good Luck,
jason
Good Luck,
jason
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
